  1. carflomi
  2. PLCnext Engineer
  3. Tuesday, 13 October 2020
Working with PLCNEXT ENGINEER and had an unexpected shutdown, then I show the information that gives the program the error
PLCnext Engineer, Version 2020.6.2 (Build 4.5.239.0)
Unexpected Exception
Channel already closed.
Exception chain:
AdeFatalCommunicationException
Details
Message:
Stack trace:
Server stack trace:
   at c30.Invoke(IMethodCallMessage A_0)
Exception rethrown at [0]:
   at c3e.Execute()
   at c6e.a(ICallStackFrame A_0)
   at c6j.get_IecInstancePath()
   at Ade.Internal.Plc.PlcCommunicationContextWrapper.a(ICallStackFrame A_0)
   at Ade.Internal.Plc.PlcCommunicationContextWrapper.<>c.a(ValueTuple`2 A_0)
   at System.Collections.Generic.List`1.ForEach(Action`1 action)
   at Ade.Internal.Plc.PlcCommunicationContextWrapper.a(ICallStackInfo A_0, Boolean A_1)
   at Ade.Internal.Plc.PlcCommunicationContextWrapper.c()
   at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)
   at System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Int32 numArgs, Delegate catchHandler)
   at System.Windows.Threading.DispatcherOperation.InvokeImpl()
   at MS.Internal.CulturePreservingExecutionContext.CallbackWrapper(Object obj)
   at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
   at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
   at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
   at MS.Internal.CulturePreservingExecutionContext.Run(CulturePreservingExecutionContext executionContext, ContextCallback callback, Object state)
   at System.Windows.Threading.DispatcherOperation.Invoke()
   at System.Windows.Threading.Dispatcher.ProcessQueue()
   at System.Windows.Threading.Dispatcher.WndProcHook(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
   at MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
   at MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o)
   at System.Windows.Threading.Dispatcher.LegacyInvokeImpl(DispatcherPriority priority, TimeSpan timeout, Delegate method, Object args, Int32 numArgs)
   at MS.Win32.HwndSubclass.SubclassWndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam)
   at MS.Win32.UnsafeNativeMethods.DispatchMessage(MSG& msg)
   at System.Windows.Threading.Dispatcher.PushFrameImpl(DispatcherFrame frame)
   at System.Windows.Application.RunDispatcher(Object ignore)
   at System.Windows.Application.RunInternal(Window window)
   at Ade.Application.ApplicationStarter.Run()
   at (String[] )
   at PCWorxNext.Startup.Main(String[] args)
In addition to this, when I am connected to the PLC debugging, it systematically disconnects in a timely manner from the PLC (note, the connection between PC and PLC is direct via network cable).
error 1
I also notice the following error when I connect to the PLC HMI
error 2
Please, any way to improve PLCNEXT ENGINEER's behavior?
Martin PLCnext Team Accepted Answer Pending Moderation
0
Votes
Undo
Sorry for the delay.
This exception will be fixed in the next release of PLCnext Engineer, version 2021.0.
~ Martin.
Phoenix Contact Electronics Headquarters - PLCnext Runtime Product Management and Support
  • Page :
  • 1
