Installing PIP without IPKG
What if you do not need a newer version of Python than the one that comes preinstalled on the controller (3.5.6), but you do want pip installed? There is a simple way to do so!
You can download the installation script via the curl command:
curl https://bootstrap.pypa.io/get-pip.py -o get-pip.py
The above command downloads an installation file to the current directory which you can execute with the following command:
python3 get-pip.py
This will install pip on your controller together with wheel and setuptools.
If you wish not to install these, you can install pip with the following command:
python3 get-pip.py --no-wheel --no-setuptools
If you do need all the new bells and whistles of the latest Python distribution I gladly advise you to watch Martins Makers blog regarding Python!
