In this Makers Blog article we discuss the possibilities and advantages which a Com Server provides to the PLCnext platform.
Introduction
The extensions modules that Phoenix Contact offers for its PLCs can for example be serial adapters like:
All extensions modules have on thing in common: they can be accessed cyclically via processdata. This provides the possibility to directly interact with the serial device from our realtime application.
In some cases this is not what we want. Instead, we want to re-use existing (C/C++) libraries and do not need the realtime context. However, we will find that these libraries usually are programmed to have direct access to a COM or TTY interface.
There are two options to create a TTY interface for a PLCnext Control
- Implement some functions (C++ / C#) that create a TTY interface for the AXL or IL serial adapters from inside the
PLCnext Runtime
. - Use of a COM-Server devices such as the GW Device Server
The GW Device Server
provides a transparent TCP to Serial
interface.
With the help of a tool like Socat
we can forward the Serial/TCP traffic directly to a pseudo TTY interface.
Using GW Device Server
also provides the possibility to communicate with the serial device on remote locations via a TLS encrypted channel.
NOTE
In this tutorial, the PLC performs as client and establishes connection to a GW Device Server
(However, it is also possible to switch the PLC Socat
to a listening option and have the GW as client actively connect to the PLC.)
Setup
Setting up the GW Device Server
We connect to the GW Device Server
via the Web Based Management.
The default IP address of the GW Device Server
is 192.168.254.254.
We use the following settings:
LAN Settings - Security
- Enable SSH Server
- Enable Telnet Server
- Disable Secure Data Mode
- Disable TFTP Server
Serial Settings
- Port 1 Configuration (COM1): Enable TCP Connection on Port 8000
- Port 2 Configuration (COM2): Enable TCP Connection on Port 8001
Testing the GW Device Server
To test if we have set up the GW Device Server
correctly, first we connect our PLC to the GW Device Server
via Ethernet.
Then we connect the two DSUB adapters of the GW Device Server
with each other.
We can quickly test the setup using the tool Telnet
With this tool, we can send data from the PLC to the GW Device Server
at Port8000/COM1 through the serial cable to Port8001/COM2 and finally recieve it back at the PLC.
We use the following commands:
ssh This email address is being protected from spambots. You need JavaScript enabled to view it.
sudo passwd root
su root
ip addr add 192.168.254.10 dev eth0
telnet 192.168.254.254 8000
## open another shell session
telnet 192.168.254.254 8001
# Type some messages
Building Socat
To build Socat
easily on a Linux OS, we use the following commands:
mkdir tmp
cd tmp
git clone git://repo.or.cz/socat.git
cd socat
## TODO: Modify to your SDK location
source /opt/pxc/release/axcf2152/2020/0/environment-setup-cortexa9t2hf-neon-pxc-linux-gnueabi
. /opt/pxc/release/axcf2152/2020/0/site-config-cortexa9t2hf-neon-pxc-linux-gnueabi
mkdir install
autoconf
./configure $CONFIGURE_FLAGS --prefix=$(pwd)/install --enable-openssl-method
make -j2
make install
Deploying and installing Socat
To deploy the Socat
installation, we execute the following script:
cd tmp
mkdir -p deploy
cd deploy
mkdir -p usr
cp -r ../../Daemon/* .
cp -r ../socat/install/* usr/
# Create package
tar -cf ../socat-binaries.tar .
cd ..
scp socat-binaries.tar This email address is being protected from spambots. You need JavaScript enabled to view it.:~/
ssh -ttt This email address is being protected from spambots. You need JavaScript enabled to view it. \
"mkdir -p /opt/plcnext/socat-binaries && \
tar -xf /opt/plcnext/socat-binaries.tar -C /opt/plcnext/socat-binaries"
After deploying, we can now ssh to our PLC. Therefore, we first prepare the PLC by setting up the directories and config files by running the following commands:
deploy$ ssh This email address is being protected from spambots. You need JavaScript enabled to view it.
This email address is being protected from spambots. You need JavaScript enabled to view it.:~$ su root
This email address is being protected from spambots. You need JavaScript enabled to view it.$ mkdir -p /etc/default/socat
This email address is being protected from spambots. You need JavaScript enabled to view it.$ touch /etc/default/socat/socat.conf
This email address is being protected from spambots. You need JavaScript enabled to view it.$ touch /etc/init.d/SocatDaemon
Now, we modify the socat.conf
file to configure the parameters of the serial interface to our needs.
nano /etc/default/socat/socat.conf
The content of the file looks like this.
TARGETIP="192.168.254.254"
TARGETPORT="8000"
TTYNAME="/dev/ttyGWDeviceServer"
OPTIONS="pty,link=$TTYNAME tcp-connect:$TARGETIP:$TARGETPORT,forever,interval=15"
BAUD="9600"
PARITY=""
DATABITS="csN 8"
STOPBITS="-cstopb"
FLOWCONTROLL=""
If we need to modify further parameters, we will need to also modify the SocatDaemon
file.
More information on TTY parameters can be found in the stty manual pages.
Now we create a SocatDaemon
file to automatically connect to the GW Device Server
using a Socat
daemon.
NOTE:
This SocatDaemon file is an example without error/disconnection management etc. please.
nano /etc/init.d/SocatDaemon
The file has the following content.
(click to see/hide code)
```bash #! /bin/sh ### BEGIN INIT INFO # Provides: socat # Required-Start: $local_fs $time $network # Required-Stop: $local_fs $time $network # Default-Start: 2 3 4 5 # Default-Stop: 0 1 6 # Short-Description: Daemon to setup Socat connection to GWd # # Description: The Socat init script will start/stop Socat as specified in /etc/default/socat/socat.conf # Logs can be found at /var/log/socat.log ### END INIT INFO NAME=socat DAEMON=/usr/bin/socat SOCAT_DEFAULTS='-d -d -d -lf /var/log/socat.log' . /etc/default/socat/socat.conf PATH=/bin:/usr/bin:/sbin:/usr/sbin [ -x $DAEMON ] || exit 0 start_socat() { start-stop-daemon --oknodo --quiet --start \ --pidfile /var/run/socat.pid \ --background --make-pidfile \ --exec $DAEMON -- $SOCAT_DEFAULTS $OPTIONS < /dev/null do_wait_tty chown admin:plcnext_firmware $TTYNAME init_tty } init_tty(){ ## For Reference ## https://man7.org/linux/man-pages/man1/stty.1.html stty -F $TTYNAME echo "-----before-------" #BAUD=9600 stty -F $TTYNAME $BAUD #PARITY="" # "" or parodd or -parodd stty -F $PARITY #DATABITS="csN 8" stty -F $TTYNAME $DATABITS #STOPBITS="-cstopb" stty -F $TTYNAME $STOPBITS #FLOWCONTROLL=none #RTS handshake crtscts echo "-----initialised-------" stty -F $TTYNAME } do_wait_tty() { TIMEOUT_COUNTER=0 TIMEOUT=25 TIMEOUTREACHED=0; ttyFOUND=1; echo "Wait for TTYNAME Files" while [ 0 -eq $TIMEOUTREACHED -a 1 -eq $ttyFOUND ]; do [ -a $TTYNAME ] ttyFOUND=$? [ $TIMEOUT_COUNTER -lt $TIMEOUT ] TIMEOUTREACHED=$? TIMEOUT_COUNTER=$[$TIMEOUT_COUNTER + 1] sleep 1 done } stop_socat() { start-stop-daemon --oknodo --stop --quiet --pidfile /var/run/socat.pid --exec $DAEMON rm -f /var/run/socat.pid } start () { start_socat return $? } stop () { for PIDFILE in `ls /var/run/socat.pid 2> /dev/null`; do NAME=`echo $PIDFILE | cut -c16-` NAME=${NAME%%.pid} stop_socat done } case "$1" in start) echo "Starting socat" if start ; then echo $? else echo $? fi ;; stop) echo "Stopping socat" if stop ; then echo $? else echo $? fi ;; restart) echo "Restarting socat" stop if start ; then echo $? else echo $? fi ;; *) echo "Usage: /etc/init.d/$NAME {start|stop|restart}" exit 3 ;; esac exit 0 ```
Now that all config files are in place, we can proceed by setting up the Socat
binaries and registering the Socat
daemon.
chmod +x /etc/init.d/SocatDaemon
cd /opt/plcnext/socat-binaries
chmod +x usr/bin/*
cp -r usr /
update-rc.d -s -v SocatDaemon 99
/etc/init.d/SocatDaemon start
If everything is set up correctly, we can see the running daemon using a command like ps -e | grep socat
We can also check the Socat
logs located at cat /var/log/socat.log
Accessing the TTY interface from a terminal
Now we can send messages over the TTY interface.
sudo echo "PLC to GW $var" > /dev/GWDeviceServer
To continuously test the pseudo TTY, we can use a command like
while true; do sleep 5 && sudo echo "PLC to GW $var" >/dev/ttyUSB0 && var=$((var+1)); done
Incoming traffic can be displayed by executing cat /dev/GWDeviceServer
Now any application can access the Serial device connected to the GW Device Server as if it is directly connected to the PLC.
