Abstract
Did you know that the PLCnext Common Classes have built in support for XML serialization? This article shows how to use the IXmlSerializable
interface to populate the data in a c++ class.
You can find the Interface description in the API documentation of the PLCnext Common Classes.
Requirements
This article was written with the following setup:
PLCnext Firmware: 2020.6 LTS PLCnext C++ SDK for Linux 64 Bit 2020.6 LTS
The data
We want to populate our class with the following configuration file.
<?xml version="1.0" encoding="UTF-8"?> <MyConfigDocument schemaVersion="1.0"> <Server dnsName="server.domain.tld" /> <FileList> <File path="$ARP_DATA_DIR$/Services/MyComponent/file1.txt" /> <File path="$ARP_DATA_DIR$/Services/MyComponent/file2.txt" /> </FileList> </MyConfigDocument>
The $ARP_DATA_DIR$
notation is a placeholder for environment variable, in this case ARP_DATA_DIR
. You can find the defined Arp environment variables in your device settings file on the target /etc/plcnext/Device.acf.settings
To be able to read the data from a XML file we have to implement the IXMLSerializable
interface for our class. To keep it simple our class has only two data elements, a DNS name and a vector of filepaths.
#pragma once #include "Arp/System/Core/Arp.h" #include "Arp/System/Commons/Xml/IXmlSerializable.hpp" #include "vector" namespace MyComponent { class MyConfiguration : public Arp::System::Commons::Xml::IXmlSerializable { public: MyConfiguration() = default; ~MyConfiguration() = default; // IXMLSerializable interface public: void ReadXml(Arp::System::Commons::Xml::XmlReader& reader, Arp::System::Commons::Xml::XmlSerializationContext& context) override; void WriteXml(Arp::System::Commons::Xml::XmlWriter& writer, Arp::System::Commons::Xml::XmlSerializationContext& context) override; // The data public: Arp::String DnsName{""}; std::vector<Arp::String> FileList; // Some supporting methods private: void readFileList(Arp::System::Commons::Xml::XmlReader& reader, Arp::System::Commons::Xml::XmlSerializationContext& context); void readFile(Arp::System::Commons::Xml::XmlReader& reader, Arp::System::Commons::Xml::XmlSerializationContext& context); }; } // namespace MyComponent
Implementation
We must implement the ReadXml
and WriteXml
Methods.
The WriteXml
Method is straight forward, we do not want to write we only want to read the data from the XML file. The ReadXml
Method is called if we want to read the data from the XML file.
#include "MyConfiguration.hpp"
void MyConfiguration::WriteXml(Arp::System::Commons::Xml::XmlWriter& writer, Arp::System::Commons::Xml::XmlSerializationContext& context)
// no operation.
return;
void MyConfiguration::ReadXml(Arp::System::Commons::Xml::XmlReader& reader, Arp::System::Commons::Xml::XmlSerializationContext& context)
Arp::String elementName;
while (reader.TryReadStartElement(elementName))
if (elementName == Arp::System::Commons::Xml::XmlSerializationContext::IncludesXmlName)
context.ReadIncludesElement(reader);
else if (elementName == "Server")
this->DnsName = reader.GetAttributeValue<Arp::String>("dnsName");
reader.ReadEndElement();
else if (elementName == "FileList")
this->readFileList(reader, context);
else
context.InvalidXmlElementOccurs(reader, elementName);
void MyConfiguration::readFileList(Arp::System::Commons::Xml::XmlReader& reader, Arp::System::Commons::Xml::XmlSerializationContext& context)
if (reader.IsEmptyElement()){
return;
if (reader.ReadToDescendant("File"))
this->readFile(reader, context);
while (reader.ReadToNextSibling("File"))
else
void MyConfiguration::readFile(Arp::System::Commons::Xml::XmlReader& reader, Arp::System::Commons::Xml::XmlSerializationContext& context)
// Use 'context.ResolvePath' to replace placeholders in the path.
auto file = Arp::String(context.ResolvePath(reader.GetAttributeValue<Arp::String>("path")));
this->FileList.push_back(file);
Read the data
We now can use our class with the XMLConfigDocument
class in the LoadConfig Method to load the data in our class.
void MyComponent::LoadConfig() { // load project config here using namespace Arp::System::Commons; this->log.Info("LoadConfig"); // Fist argument has to match the XML root element name. // Our MyConfiguration instance this->config will be populated. Xml::XmlConfigDocument configDoc("MyConfigDocument", this->config); if (!Io::File::Exists(this->settingsPath)) { this->log.Error("Configuration file '{}' does not exist.", this->settingsPath); return; } try { configDoc.Load(this->settingsPath); } catch (const Arp::Exception& e) { this->log.Error(e.GetMessage()); throw InvalidConfigException(e.GetMessage()); } }
