Linq the list processing library for C++
Peer PLCnext Team 09 December 2020 min. read
257 views 0 comments
Abstract
In this article I will explain how to use linq to process data. With this library you can use filtering, selections, aggregations, groupings and many more. For full support it requires clang or gcc, and boost
How to use
This library is a Header only library. You only have to integrate the C++ header in your project environment. When you’re done you can use the linq functions.
Select
    std::vector<int> v = { 1, 2, 4 };
    //linq form
    auto q = LINQ(from(x, v) select(x * 3));
    //q -> result {3,6,12}
    //extension form
    auto r = v
        | linq::select([](int x) { return x * 3; });
OrderBy
    std::vector<int> v = { 4, 2, 8 };
    //linq form
    auto q = LINQ(from(x, v) orderby( descending x) select(x));
    //q -> result {8,4,2}
Where
    vector<int> v = { 1, 3, 4, 5 };
    auto q = LINQ(from(i, v) where(i % 2));
    //q -> result {4}
    //extension form
    auto r = v
        | linq::where([](int x){ return x % 2})
        | linq::select([](int x) { return x; });
More Information
If you are interested in getting more information about linq you can check the folowing links:
License
The library is published under Boost Software License 1.0
