Connecting Factory IO training simulator to PLCnext with OPC UA client
seafoxc 08 May 2021 min. read
1,438 views 2 comments
How to connect Factory I/O with PLCnext
Factory I/O is a virtual environment that is designed to be linked with PLC’s in order to teach, test and train.
It is a great addition to get to know PLCnext other then the inputs and outputs provided by the starter kit.
You can use Factory I/O for free for a 30 day trail (without giving your credit card info).
https://factoryio.com/
How to make the connection
In factory I/O you can set-up an OPC-UA client that can connect to the OPC-UA server we can set-up in PLCnext. There are some small things to makes this work. I made a very dense video with the info on how to connect Factory IO with PLC next. I made this because it took a few hours for me to figure out how to set it up and I want to save others the trouble.
Please accept marketing-cookies to watch this video.
 I hoped it helped you connecting Factory I/O to PLC next and I wish you a great day!!!
Seafoxc 15.12.2021
The link was deleted from my post. Here is the video tutorial: https://youtu.be/cTAbPPl6vIU
PLCnext Team 15.11.2022
Thanks for the link, Seafoxc. Embedded the video again.
Seafoxc 15.11.2022
I almost forgot about this comment. 11 months later, but still, thank you! :-)
thabiso@98 24.09.2023
but How do i connect if i dont have the actual hardware?
