Message management library for plc applications using IEC-61131 and eHMI
w.sommer 11 October 2021 min. read
288 views 0 comments
Introduction
The CXMM_MessageManagement library offers functions to display information-, warning-, error- and other messages from the application program on the hmi. The design lean on the PLCnext WBM notification display.
CXMM MessageDisplay
First steps example
Set the message text to the plc variable udtTextBuffer
It is recommended to store the message text in an csv file and to use the FB PBCL_FileCsvRead from the PLCnextBase library to set the data to the pls variable.
Set text for the sender column
For the sender column set the parameters as follow:
uiSender > 0, wCode = 0, wAddCode = 0
CXMM_udtMessageMgr.udtTextBuffer.arrText[0].uiSender := 12345;
CXMM_udtMessageMgr.udtTextBuffer.arrText[0].wCode    := WORD#16#0;
CXMM_udtMessageMgr.udtTextBuffer.arrText[0].wAddCode := WORD#16#0;
CXMM_udtMessageMgr.udtTextBuffer.arrText[0].strText  := 'My_FB';
Set text for the message column
For the message column set the parameters as follow:
uiSender > 0, wCode > 0, wAddCode > 0
CXMM_udtMessageMgr.udtTextBuffer.arrText[1].uiSender := 12345;
CXMM_udtMessageMgr.udtTextBuffer.arrText[1].wCode    := WORD#16#8001;
CXMM_udtMessageMgr.udtTextBuffer.arrText[1].wAddCode := WORD#16#1001;
CXMM_udtMessageMgr.udtTextBuffer.arrText[1].strText  := 'Not in position';
Example how to use the PBCL_FileCsvRead FB
PBCL_FileCsvRead(
    uiOffset        := UINT#1,
    strFileName     := strFileNameFileCsvRead,
    strDataTypes    := 'UINT;WORD;WORD;STRING' ,
    strDelimiter    := ';',
    udiRowCnt       => udiRowCntFileCsvRead,
    anyTable        := CXMM_udtMessageMgr.udtTextBuffer.arrText);
MessageText csv
Instantiate the function block CXMM_MessageManager
CXMM_MessageManager(udtMessageMgr := CXMM_udtMessageMgr);
Instantiate the hmi symbol CXMM_MessageDisplay
Connect it to the CXMM_MessageManager function block.
CXMM MessageDisplayParameter
Instantiate the function block CXMM_SendMessage
CXMM_SendMessage_11(
    xSend           := xSend,
    uiSender        := UINT#12345,
    uiSenderType    := UINT#0,
    wCode           := WORD#1,
    wAddCode        := WORD#0,
    enSeverity      := CXMM_enSeverity#Error,
CXMM_MessageDisplay show the message text
CXMM SendInfoDisplay
 Download the library: https://github.com/WaldemarSommer22/MessageManagement-iec61131-plcnext.git
