This site uses cookies for functional purposes. To continue please read and agree to our Data Privacy.
By closing this message, you consent to our use of cookies on this device.
How to send a mail via Node-Red
To be able to follow this blog, you must have alreday installe the OPC-UA inside Node-Red.
Then, it will be possible to send a mail, with a command from the PLC (xSend) including a variable message (strText).
Here are the 2 variables of the AXC F 2152 which will be used and accessible by OPC UA :
1
OPC option must be checked.
In the Node-Red flow, insert this code :
2
The ‘debug’ output are just for help.
First, you need to access to the OPC variables, and scan each 5 seconds their value.
3
Wait for the OPC UA server responses :
4
To get the value of xSend
5
If xSend = True, extract the strText
6
Then send the message to a defined mail adress :
7
Of course, you have to adapt the name of the server, mail adress, etc…
Then, you will just need to define the text to send in strText in the AXC F 2152 and set xSend to TRUE.
It is of course necessary to reset xSend. For this, the second part of the flow is used :
Cyclically, set xSend to FALSE :
8
Send the value to the OPC UA server :
9
10 permit to control the write process.
10permits to send the mail from Node-Red, for test, for example. It sets xSend to TRUE.
Here is the code of the flow for firmware v1.x (click the triangle).
"id": "d35d5c3c.16ca7",
"type": "tab",
"label": "Send Mail",
"disabled": false,
"info": ""
"id": "a417b066.f07e6",
"type": "OPCUA-IIoT-Inject",
"z": "d35d5c3c.16ca7",
"injectType": "read",
"payload": "",
"payloadType": "date",
"topic": "",
"repeat": "5",
"crontab": "",
"once": false,
"startDelay": "",
"name": "",
"addressSpaceItems": [
"name": "xSend",
"nodeId": "ns=4;s=Arp.Plc.Eclr/MainInstance:xSend",
"datatypeName": ""
"name": "",
"nodeId": "ns=4;s=Arp.Plc.Eclr/MainInstance:strText",
"datatypeName": ""
"x": 230,
"y": 260,
"wires": [
"19ec98c.8b95567"
"id": "7fa00122.04423",
"type": "debug",
"name": "",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "true",
"x": 1210,
"y": 120,
"wires": []
"id": "6127de4a.84662",
"type": "debug",
"name": "",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "payload[0].value",
"x": 1260,
"y": 160,
"wires": []
"id": "a0ccf188.25283",
"type": "comment",
"name": "Lecture texte à envoyer",
"info": "",
"x": 160,
"y": 80,
"wires": []
"id": "84cb685c.e42538",
"type": "change",
"name": "",
"rules": [
"t": "set",
"p": "payload",
"pt": "msg",
"to": "payload[1].value",
"tot": "msg"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 1000,
"y": 260,
"wires": [
"bf1e6f8f.b43d8",
"7fa00122.04423",
"6127de4a.84662"
"id": "bf1e6f8f.b43d8",
"type": "e-mail",
"server": "smtp.gmail.com",
"port": "465",
"secure": true,
"name": "This email address is being protected from spambots. You need JavaScript enabled to view it.",
"dname": "Mail depuis node Red",
"x": 1220,
"y": 260,
"wires": []
"id": "19ec98c.8b95567",
"type": "OPCUA-IIoT-Read",
"attributeId": "13",
"maxAge": 1,
"depth": 1,
"connector": "626ceb71.fa9014",
"name": "Look at xSend",
"justValue": true,
"showStatusActivities": true,
"showErrors": true,
"parseStrings": false,
"historyDays": "",
"x": 400,
"y": 260,
"wires": [
"105cbdfe.da7492"
"id": "105cbdfe.da7492",
"type": "OPCUA-IIoT-Response",
"name": "",
"compressStructure": true,
"showErrors": true,
"activateUnsetFilter": false,
"activateFilters": false,
"negateFilter": false,
"filters": [],
"x": 590,
"y": 260,
"wires": [
"5297841f.927fec",
"1456a43.819955c",
"72f252c2.58f50c"
"id": "5297841f.927fec",
"type": "debug",
"name": "",
"active": false,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "payload[1].value",
"x": 900,
"y": 440,
"wires": []
"id": "1456a43.819955c",
"type": "switch",
"name": "Test xSend",
"property": "payload[0].value",
"propertyType": "msg",
"rules": [
"t": "true"
"checkall": "true",
"repair": false,
"outputs": 1,
"x": 810,
"y": 260,
"wires": [
"84cb685c.e42538",
"785029ef.0c5c48"
"id": "72f252c2.58f50c",
"type": "debug",
"name": "",
"active": false,
"tosidebar": true,
"console": false,
"tostatus": false,
"x": 900,
"y": 380,
"wires": []
"id": "785029ef.0c5c48",
"type": "debug",
"name": "",
"active": false,
"tosidebar": true,
"console": false,
"tostatus": false,
"x": 940,
"y": 320,
"wires": []
"id": "c1606c74.2cbdc",
"injectType": "write",
"payload": "false",
"payloadType": "bool",
"topic": "",
"repeat": "5",
"crontab": "",
"once": false,
"startDelay": "",
"name": "",
"name": "xSend",
"datatypeName": "Boolean"
"x": 150,
"y": 840,
"wires": [
"8ade696b.6cc148"
"id": "8ade696b.6cc148",
"type": "OPCUA-IIoT-Write",
"name": "Control xSend",
"justValue": true,
"showStatusActivities": false,
"showErrors": true,
"x": 360,
"y": 840,
"wires": [
"fcb3a665.c8ce98"
"id": "fcb3a665.c8ce98",
"name": "",
"compressStructure": false,
"showErrors": false,
"filters": [],
"x": 560,
"y": 840,
"wires": [
"205cfbb9.8ba974"
"id": "205cfbb9.8ba974",
"type": "debug",
"name": "",
"active": false,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "true",
"x": 730,
"y": 840,
"wires": []
"id": "fcaacf6d.574ba",
"payload": "true",
"topic": "",
"repeat": "",
"crontab": "",
"once": false,
"startDelay": "",
"name": "",
"name": "xSend",
"x": 170,
"y": 900,
"wires": [
"8ade696b.6cc148"
"id": "ef302fdf.a0388",
"type": "comment",
"name": "controle xSend",
"info": "",
"x": 180,
"y": 800,
"wires": []
"id": "626ceb71.fa9014",
"type": "OPCUA-IIoT-Connector",
"z": "",
"discoveryUrl": "",
"endpoint": "opc.tcp://127.0.0.1:4840",
"keepSessionAlive": true,
"loginEnabled": false,
"securityPolicy": "Basic128Rsa15",
"securityMode": "SIGNANDENCRYPT",
"name": "LOCAL SERVER",
"showErrors": true,
"individualCerts": false,
"publicCertificateFile": "",
"privateKeyFile": "",
"defaultSecureTokenLifetime": "",
"endpointMustExist": false,
"autoSelectRightEndpoint": false,
"strategyMaxRetry": "",
"strategyInitialDelay": "",
"strategyMaxDelay": "",
"strategyRandomisationFactor": "",
"requestedSessionTimeout": "",
"connectionStartDelay": "",
"reconnectDelay": "",
"maxBadSessionRequests": "10"
With the new firmware version 2019.0, it is now impossible to write a value from node-Red to an OPC UA OutPort.
So, here is a new flow using xSend and xSent as variables to send the mail and to inform the AXC F 2152 that the mail has been sent (click the triangle).
    "id":"10110044.30b59",
    "type": "tab",
    "disabled": false,
    "info": ""
    "id": "d0cb2109.ab173",
    "z": "10110044.30b59",
    "payload": "",
    "topic": "",
    "repeat": "5",
    "crontab": "",
    "once": false,
    "startDelay": "",
    "name": "Scan xSend ...",
            "name": "xSend",
            "nodeId": "ns=5;s=Arp.Plc.Eclr/MainInstance.xSend",
            "datatypeName": ""
            "name": "",
            "nodeId": "ns=5;s=Arp.Plc.Eclr/MainInstance.strText",
            "datatypeName": ""
            "name": "",
            "nodeId": "ns=5;s=Arp.Plc.Eclr/MainInstance.xSent",
            "datatypeName": ""
            "name": "",
            "nodeId": "ns=5;s=Arp.Plc.Eclr/MainInstance.strMailTo",
            "datatypeName": ""
            "name": "",
            "nodeId": "ns=5;s=Arp.Plc.Eclr/MainInstance.strMailCC",
            "datatypeName": ""
            "name": "",
            "nodeId": "ns=5;s=Arp.Plc.Eclr/MainInstance.strMailBCC",
            "datatypeName": ""
    "x": 194,
    "y": 257.9999990463257,
    "wires": [["4c0f65aa.553d3c"]]
    "id": "e3f86348.7ae06",
    "type": "comment",
    "name": "Read text to submit",
    "info": "",
    "x": 160,
    "y": 80,
    "wires":[]
    "id": "33c9ab4f.6e6904",
    "type": "change",
    "name": "copy strText in Mail",
    "rules":
            "t": "set",
            "p": "to",
            "pt": "msg",
            "to": "payload[3].value",
            "tot": "msg"
            "t": "set",
            "p": "cc",
            "pt": "msg",
            "to": "payload[4].value",
            "tot":"msg"
            "t": "set",
            "p": "bcc",
            "pt": "msg",
            "to": "payload[5].value",
            "tot": "msg"
            "t": "set",
            "p": "payload",
            "pt": "msg",
            "tot": "msg"
    "action": "",
    "property": "",
    "from": "",
    "to": "",
    "reg": false,
    "x": 1309.0000228881836,
    "y": 255.00000953674316,
    "wires":[["ab1624f6.a3f398","7518e5a1.a4f6bc","4b371b6a.c3f7c4"]]
    "id": "ab1624f6.a3f398",
    "type": "e-mail",
    "port": "465",
    "secure": true,
    "name": "",
    "dname": "Sending mail",
    "x": 1550.0000953674316,
    "y": 254.00000953674316,
    "wires": []
    "id": "4c0f65aa.553d3c",
    "maxAge": 1,
    "depth": 1,
    "connector": "21582029.3743a",
    "name": "...in the local server",
    "justValue": true,
    "showErrors": true,
    "historyDays": "",
    "x": 400,
    "y": 256.9999990463257,
    "wires": [["8b5a0cd8.fb222"]]
    "id":"8b5a0cd8.fb222",
    "type":"OPCUA-IIoT-Response",
    "z":"10110044.30b59",
    "name":"Wait for answer",
    "compressStructure":true,
    "showStatusActivities":true,
    "showErrors":true,
    "activateUnsetFilter":false,
    "activateFilters":false,
    "negateFilter":false,
    "filters":[],
    "x":629.9999961853027,
    "y":255.99999809265137,
    "wires":[["4abaa77f.5c3dc8","7c7aec60.dd4ea4","abdef645.a4af28"]]
    "id":"4abaa77f.5c3dc8",
    "type":"switch",
    "name":"Test xSend = true",
    "property":"payload[0].value",
    "propertyType":"msg",
    "rules":[{"t":"true"}],
    "checkall":"true",
    "repair":false,
    "outputs":1,
    "x":839,
    "y":257.99999809265137,
    "wires":[["6198d7d9.ae24f8"]]
    "id":"7518e5a1.a4f6bc",
    "type":"OPCUA-IIoT-Node",
    "injectType":"write",
    "nodeId":"ns=5;s=Arp.Plc.Eclr/MainInstance.xSent",
    "datatype":"Boolean",
    "value":"true",
    "name":"Set xSent = true",
    "topic":"",
    "showErrors":false,
    "x":1556.886817932129,
    "y":303.45702934265137,
    "wires":[["e7f659ad.f856d8"]]
    "id":"e7f659ad.f856d8",
    "type":"OPCUA-IIoT-Write",
    "connector":"21582029.3743a",
    "name":"send to local server",
    "justValue":true,
    "showErrors":true,
    "x":1807.0199127197266,
    "y":434.0039281845093,
    "wires":[["17416cc1.3e6113"]]
    "id":"17416cc1.3e6113",
    "compressStructure":false,
    "showStatusActivities":false,
    "showErrors":false,
    "filters":[],
    "x":2036.020004272461,
    "y":434.003981590271,
    "wires":[["33609b88.7c4cc4"]]
    "id":"33609b88.7c4cc4",
    "type":"debug",
    "name":"",
    "active":false,
    "tosidebar":true,
    "console":false,
    "tostatus":false,
    "complete":"true",
    "x":2223.020030975342,
    "y":434.0039348602295,
    "wires":[]
    "id":"6198d7d9.ae24f8",
    "type":"switch",
    "name":"Test xSent = false",
    "property":"payload[2].value",
    "rules":[{"t":"false"}],
    "checkall":"true",
    "repair":false,
    "outputs":1,
    "x":1075.0195999145508,
    "y":258.00392723083496,
    "wires":[["33c9ab4f.6e6904"]]
    "id":"e4f13e7.aeee0c",
    "value":"",
    "name":"Set xSent = false",
    "topic":"ns=5;s=Arp.Plc.Eclr/MainInstance.xSent",
    "showErrors":false,
    "x":1559.519676208496,
    "y":432.0040044784546,
    "id":"bbf31571.bd4798",
    "type":"change",
    "name":"set xSent = false",
    "rules":
            "t":"set",
            "p":"payload",
            "pt":"msg",
            "to":"false",
            "tot":"bool"
    "action":"",
    "property":"",
    "from":"",
    "to":"",
    "reg":false,
    "x":1300.5198135375977,
    "y":436.0039463043213,
    "wires":[["e4f13e7.aeee0c"]]
    "id":"7c7aec60.dd4ea4",
    "type":"switch",
    "name":"Test xSend = false",
    "checkall":"true",
    "repair":false,
    "outputs":1,
    "x":828.5195541381836,
    "y":433.00390815734863,
    "wires":[["bbf31571.bd4798"]]
    "id":"abdef645.a4af28",
    "type":"debug",
    "name":"",
    "active":false,
    "tosidebar":true,
    "console":false,
    "tostatus":false,
    "complete":"false",
    "x":977.89453125,
    "y":648.67578125,
    "wires":[]
    "id":"4b371b6a.c3f7c4",
    "type":"debug",
    "name":"",
    "active":false,
    "tosidebar":true,
    "console":false,
    "tostatus":false,
    "complete":"true",
    "x":1534.0195121765137,
    "y":126.00390434265137,
    "wires":[]
    "id":"21582029.3743a",
    "type":"OPCUA-IIoT-Connector",
    "z":"",
    "discoveryUrl":"",
    "endpoint":"opc.tcp://127.0.0.1:4840",
    "keepSessionAlive":true,
    "loginEnabled":false,
    "securityPolicy":"Basic128Rsa15",
    "securityMode":"SIGNANDENCRYPT",
    "name":"LOCAL SERVER",
    "showErrors":true,
    "individualCerts":false,
    "publicCertificateFile":"",
    "privateKeyFile":"",
    "defaultSecureTokenLifetime":"",
    "endpointMustExist":false,
    "autoSelectRightEndpoint":false,
    "strategyMaxRetry":"",
    "strategyInitialDelay":"",
    "strategyMaxDelay":"",
    "strategyRandomisationFactor":"",
    "requestedSessionTimeout":"",
    "connectionStartDelay":"",
Comments
# mschneider 2019-02-27 15:55
With the new version 2019.0, it is now impossible to write a value from node-Red to an OPC UA OutPort.
So, here is a new flow using xSend and xSent as variables to send the mail and to inform the AXC F 2152 that the mail has been sent :
[{"id":"10110044.30b59","type":"tab","label":"Send Mail","disabled":false,"info":""},{"id":"d0cb2109.ab173","type":"OPCUA-IIoT-Inject","z":"10110044.30b59","injectType":"read","payload":"","payloadType":"date","topic":"","repeat":"5","crontab":"","once":false,"startDelay":"","name":"Scan xSend ...","addressSpaceItems":[{"name":"xSend","nodeId":"ns=5;s=Arp.Plc.Eclr/MainInstance.xSend","datatypeName":""},{"name":"","nodeId":"ns=5;s=Arp.Plc.Eclr/MainInstance.strText","datatypeName":""},{"name":"","nodeId":"ns=5;s=Arp.Plc.Eclr/MainInstance.xSent","datatypeName":""},{"name":"","nodeId":"ns=5;s=Arp.Plc.Eclr/MainInstance.strMailTo","datatypeName":""},{"name":"","nodeId":"ns=5;s=Arp.Plc.Eclr/MainInstance.strMailCC","datatypeName":""},{"name":"","nodeId":"ns=5;s=Arp.Plc.Eclr/MainInstance.strMailBCC","datatypeName":""}],"x":194,"y":257.9999990463257,"wires":[["4c0f65aa.553d3c"]]},{"id":"e3f86348.7ae06","type":"comment","z":"10110044.30b59","name":"Lecture texte à envoyer","info":"","x":160,"y":80,"wires":[]},{"id":"33c9ab4f.6e6904","type":"change","z":"10110044.30b59","name":"copy strText in Mail","rules":[{"t":"set","p":"to","pt":"msg","to":"payload[3].value","tot":"msg"},{"t":"set","p":"cc","pt":"msg","to":"payload[4].value","tot":"msg"},{"t":"set","p":"bcc","pt":"msg","to":"payload[5].value","tot":"msg"},{"t":"set","p":"payload","pt":"msg","to":"payload[1].value","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1309.0000228881836,"y":255.00000953674316,"wires":[["ab1624f6.a3f398","7518e5a1.a4f6bc","4b371b6a.c3f7c4"]]},{"id":"ab1624f6.a3f398","type":"e-mail","z":"10110044.30b59","server":"smtp.gmail.com","port":"465","secure":true,"name":"","dname":"Sending mail","x":1550.0000953674316,"y":254.00000953674316,"wires":[]},{"id":"4c0f65aa.553d3c","type":"OPCUA-IIoT-Read","z":"10110044.30b59","attributeId":"13","maxAge":1,"depth":1,"connector":"21582029.3743a","name":"... In the local server","justValue":true,"showStatusActivities":true,"showErrors":true,"parseStrings":false,"historyDays":"","x":400,"y":256.9999990463257,"wires":[["8b5a0cd8.fb222"]]},{"id":"8b5a0cd8.fb222","type":"OPCUA-IIoT-Response","z":"10110044.30b59","name":"Wait for answer","compressStructure":true,"showStatusActivities":true,"showErrors":true,"activateUnsetFilter":false,"activateFilters":false,"negateFilter":false,"filters":[],"x":629.9999961853027,"y":255.99999809265137,"wires":[["4abaa77f.5c3dc8","7c7aec60.dd4ea4","abdef645.a4af28"]]},{"id":"4abaa77f.5c3dc8","type":"switch","z":"10110044.30b59","name":"Test xSend = true","property":"payload[0].value","propertyType":"msg","rules":[{"t":"true"}],"checkall":"true","repair":false,"outputs":1,"x":839,"y":257.99999809265137,"wires":[["6198d7d9.ae24f8"]]},{"id":"7518e5a1.a4f6bc","type":"OPCUA-IIoT-Node","z":"10110044.30b59","injectType":"write","nodeId":"ns=5;s=Arp.Plc.Eclr/MainInstance.xSent","datatype":"Boolean","value":"true","name":"Set xSent = true","topic":"","showErrors":false,"x":1556.886817932129,"y":303.45702934265137,"wires":[["e7f659ad.f856d8"]]},{"id":"e7f659ad.f856d8","type":"OPCUA-IIoT-Write","z":"10110044.30b59","connector":"21582029.3743a","name":"send to local server","justValue":true,"showStatusActivities":true,"showErrors":true,"x":1807.0199127197266,"y":434.0039281845093,"wires":[["17416cc1.3e6113"]]},{"id":"17416cc1.3e6113","type":"OPCUA-IIoT-Response","z":"10110044.30b59","name":"Wait for answer","compressStructure":false,"showStatusActivities":false,"showErrors":false,"activateUnsetFilter":false,"activateFilters":false,"negateFilter":false,"filters":[],"x":2036.020004272461,"y":434.003981590271,"wires":[["33609b88.7c4cc4"]]},{"id":"33609b88.7c4cc4","type":"debug","z":"10110044.30b59","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","x":2223.020030975342,"y":434.0039348602295,"wires":[]},{"id":"6198d7d9.ae24f8","type":"switch","z":"10110044.30b59","name":"Test xSent = false","property":"payload[2].value","propertyType":"msg","rules":[{"t":"false"}],"checkall":"true","repair":false,"outputs":1,"x":1075.0195999145508,"y":258.00392723083496,"wires":[["33c9ab4f.6e6904"]]},{"id":"e4f13e7.aeee0c","type":"OPCUA-IIoT-Node","z":"10110044.30b59","injectType":"write","nodeId":"ns=5;s=Arp.Plc.Eclr/MainInstance.xSent","datatype":"Boolean","value":"","name":"Set xSent = false","topic":"ns=5;s=Arp.Plc.Eclr/MainInstance.xSent","showErrors":false,"x":1559.519676208496,"y":432.0040044784546,"wires":[["e7f659ad.f856d8"]]},{"id":"bbf31571.bd4798","type":"change","z":"10110044.30b59","name":"set xSent = false","rules":[{"t":"set","p":"payload","pt":"msg","to":"false","tot":"bool"}],"action":"","property":"","from":"","to":"","reg":false,"x":1300.5198135375977,"y":436.0039463043213,"wires":[["e4f13e7.aeee0c"]]},{"id":"7c7aec60.dd4ea4","type":"switch","z":"10110044.30b59","name":"Test xSend = false","property":"payload[0].value","propertyType":"msg","rules":[{"t":"false"}],"checkall":"true","repair":false,"outputs":1,"x":828.5195541381836,"y":433.00390815734863,"wires":[["bbf31571.bd4798"]]},{"id":"abdef645.a4af28","type":"debug","z":"10110044.30b59","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":977.89453125,"y":648.67578125,"wires":[]},{"id":"4b371b6a.c3f7c4","type":"debug","z":"10110044.30b59","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","x":1534.0195121765137,"y":126.00390434265137,"wires":[]},{"id":"21582029.3743a","type":"OPCUA-IIoT-Connector","z":"","discoveryUrl":"","endpoint":"opc.tcp://127.0.0.1:4840","keepSessionAlive":true,"loginEnabled":false,"securityPolicy":"Basic128Rsa15","securityMode":"SIGNANDENCRYPT","name":"LOCAL SERVER","showErrors":true,"individualCerts":false,"publicCertificateFile":"","privateKeyFile":"","defaultSecureTokenLifetime":"","endpointMustExist":false,"autoSelectRightEndpoint":false,"strategyMaxRetry":"","strategyInitialDelay":"","strategyMaxDelay":"","strategyRandomisationFactor":"","requestedSessionTimeout":"","connectionStartDelay":"","reconnectDelay":"","maxBadSessionRequests":"10"}]
# g.br 2019-03-07 15:31
...code integrated at the end of the article for more convenience...
