This site uses cookies for functional purposes. To continue please read and agree to our Data Privacy.
By closing this message, you consent to our use of cookies on this device.
  1. pynl02
  2. PLCnext Technology & PLCnext Controls
  3. Friday, 08 February 2019
  4.  Subscribe via email
I'm trying to implement function blocks with C# that implement a TCP server. I could implement the code with the TcpListener and have no Problem
implementing the FB in PCWorxEngineer. But when I try to connect the PLC always fails.
Are there any example code for implementing TCP sockets or any other help?
Martin PLCnext Team Accepted Answer Pending Moderation
0
Votes
Undo
I'm guessing that, in your C# code, the TCP function "blocks" the Execute method and so the Task Watchdog timer is triggered.
You can check this by looking at the contents of the ~/logs/Output.log file on the PLC after it stops. There should be a message describing what caused the PLC to stop.
There is currently no up-to-date example I can share, but there has now been a feature request raised on the CSharpExamples GitHub repository on the issue of blocking calls. Please follow this issue and/or perhaps raise your own Feature Request (for a TCP Server example) on this GitHub repository.
Hope this helps.
- Martin
Phoenix Contact Electronics Headquarters - PLCnext Runtime Product Management and Support
pynl02 Accepted Answer Pending Moderation
0
Votes
Undo
Your Tip with the blocking issue was helpful. By redesigning the function block I fixt my Problem. Now My TCP server is working
  • Page :
  • 1
There are no replies made for this post yet.
However, you are not allowed to reply to this post.
