PLCnext on LinkedInPLCnext on Instagram  PLCnext on YouTube Github PLCnext CommunityStore PLCnext Community
  1. d.vanschoorisse@uboatworx.com
  2. PLCnext Engineer
  3. Thursday, 28 February 2019
I'm testing the new PLCnext Engineer IDE together with the AXC F 2152. I'm looking into the possibilities to port an existing IEC61131-3 application from PC Worx 6.
I have imported datatypes and POU's via the import/export PLCopen functions in both PC Worx and PLCnext. However, the application utilizes the ControlTechnology library (i.e. for the functions POLG_N, LAG1ST and LIMITROC). This library does not seem to be available yet for PLCnext Engineer. Is there a possibility to import the old library, or does Phoenix Contact need to port the library?
Jan-Willem Steenbergen Accepted Answer Pending Moderation
0
Votes
Undo
Hello David,
As discussed on the Phone, we supplied you with a converted library
This library is not tested and you will use it only for testing purposes
Kind regards,
Jan-Willem
Phoenix Contact B.V. (the Netherlands) - Technical Consultant
  1. more than a month ago
  2. PLCnext Engineer
  3. # 1
  • Page :
  • 1
There are no replies made for this post yet.
However, you are not allowed to reply to this post.
