Web-based Management 2:
Security → User management
Valid from firmware release 2025.0 - for earlier firmware see WBM User Authentication
By default, on a PLCnext Control only a single user is configured and assigned to the Admin user role.
Note: Access to the specific pages in the WBM 2 depends on user roles and their rights - see WBM 2: Accessibility for details.
Of course, other users and user roles need to be assigned once the controller is put into production, which is done by means of this User management WBM 2 page. The procedure is designed to be mostly self-explanatory: By clicking the icon, you'll be led through a step-by-step configuration. See Password complexity rules for requirements to the passwords.
Security iconPlease note the guidelines in our PLCnext Technology ‑ Security Info Center.
For developing secure-by-design, IEC 62443‑2 compliant applications with PLCnext Technology, get a good grasp of the concepts used in the Security context.
Existing user roles and their permissions
User roles on Web‑based Management 2 pages
Note: Visibility of WBM 2 pages depends on the device and firmware release in use.
In addition, some WBM 2 pages could have been deactivated by settings in the System Services WBM 2 page.
WBM 2 pages Page and tab access: User role
Admin SecurityEngineer SecurityAuditor CertificateManager UserManager Engineer Commissioner Service DataViewer DataChanger Viewer
Overview
Device section General Data
Diagnostics section PROFINET
Notifications
[sec] access to security notifications
[sec]
[sec]
[sec]
Axioline
INTERBUS
Integrated UPS
ESM statistics
Configuration section Network
[r] read-only access
[r|s] read access and
reset statstics
IP configuration [r|s]     [r|s] [r|s] [r|s]
Netload limiter [r|s]       [r] [r]
NetNames
(from 2026.0 LTS)
Web Services
PLCnext Store
Proficloud
Date and Time
SPLC
Fan control
RPLC
Security
section
SD card
Firewall
Syslog
Project integrity
      [r]
Certificate management
User management
User policies
LDAP configuration
Security Profile
System
section
Device maintenance
[c] can only change the user password
[nr] cannot reboot oder reset the device
[c] [c] [nr] [nr] [nr] [c] [c] [c]
App management
System services
(from firmware 2026.0 LTS)
      [r]
Backup & restore
License management
Update
Known issue
Known for firmware 2025.0 on AXC F x152 , RFC 4072S, and BPC 9102S – fixed with firmware 2025.6:
With firmware 2025.0, the user role SecurityAdmin has been renamed to SecurityEngineer but the permissions stayed the same. With this release, a minor issue is present: The SecurityEngineer user role must be used together with the Admin user role. This is rectified in version 2025.6.
User roles in other contexts
PLCnext Engineer
Note: User roles that are not mentioned in a table do not have any access permission in the mentioned features in PLCnext Engineer.
PLCnext Engineer Access permission for: User role
Admin SecurityAdmin Engineer Commissioner Service DataViewer DataChanger Viewer EHmiViewer EHmiChanger SafetyEngineer
PLCnext Engineer
user interface
View values in the cockpit (e.g., utilization)
Transfer a project to the controller
Start (cold/warm restart) or stop the controller
Restart the controller (reboot)
Reset the controller to default setting type 1
View online variable values
Overwrite variables
Set and delete breakpoints
Download safety-related programs to the controller
[4]
[5]
Start or stop safety-related programs
[4]
[5]
Debug safety-related programs
[4]
[5]
PLCnext Engineer
HMI application
Overwrite variables
  1. As of firmware 2023.0 LTS, safety permissions for the Engineer user role are always enabled. As of the firmware 2023.0.1 LTS hotfix: if the Security Profile is enabled, safety permissions for the Engineer user role are disabled. If needed, use the SafetyEngineer user role in addition. See detailed description of combined safety user roles.
  2. Do not use this user role alone. This role is designed for use as an add-on to other user roles, e.g. Engineer. See detailed description of combined safety user roles.
Applications and services
Note: User roles that are not mentioned in a table do not have any access permission in the mentioned applications and services.
Note: Additional roles may be necessary, e.g. for use with the Device and Update Management.
Application or
service
Admin SecurityAdmin Engineer Service DataViewer DataChanger Viewer FileReader FileWriter SoftwareUpdate SafetyUpdater
SD card,
parameterization memory
SFTP access to the file system with an SFTP client
[6]
Shell SSH access to the shell
[6]
By means of dedicated tools Update safety-related firmware on the controller
OPC UA® access by means of a client application View online variable values
Overwrite variables
Read files
(OPC UA file transfer must be
enabled via PLCnext Engineer)
Write files
Update firmware on the controller
Device and Update Management (DaUM) Update firmware, software and projects
  1. Authentication with a user name and password is always required for SSH or SFTP access, even if user authentication is disabled.
• Published/reviewed: 2026-07-31  ☀  Revision 099 •
