Web‑based Management 2:
System → Backup & restore
Valid from firmware release 2025.0; extended from 2026.0 LTS
The Backup & restore page can be used to create a backup of specified data on a controller and restore some (or all of it) on the same device, or on a different device of the same type.
Note: Access to the specific pages in the WBM 2 depends on user roles and their rights - see WBM 2: Accessibility for details.
Security shieldSecurity Note: In case of suspected tampering with data on the device, make sure to reset the device to factory defaults before restoring the data from the backup. Do not just restore the data from a backup: The tampering may have been done in a way that would not be remedied by restoring the backed-up data but users wouldn't notice that.
About the Backup & restore feature
Restrictions for 2025.x versions
  • Restoring data is restricted to devices of the same device type with the same firmware version, at least the major and minor version (e.g. 2025.0.x); the last digit of the version number may differ.
  • In the Remaining files category of data, files that don't belong to the PLCnext firmware process cannot be restored.
  • Depending on the data categories selected, the PLCnext Runtime needs to be stopped safely by means of the PrepareForUpdate state machine. Therefore, backing up or restoring should never take place during productive operation of the device.
  • Preparing the WBM 2 page for secure transfer of backup packages over the network is subject to further development. Therefore, as of now it is not recommended to download backup packages from the device manually. If necessary, see Firmware directories.
Selectable data categories
Configuration data
For backing up, this category contains configurations made in several WBM 2 pages:
  • Configuration section:
    • Network
    • Web Services
    • PLCnext Store
    • Proficloud
    • Date & Time
    • SPLC
  • Security section
    • Firewall
    • Syslog
    • Project integrity
    • Certificate management
    • User management
    • LDAP configuration
    • Security Profile
  • System section
    • System services
    • License management
In addition, the DataLogger configuration is included in the backup.
When restoring, you can also select to restore only data from these subordinate-level categories:
  • Configuration User database
  • Configuration Firewall configuration
  • Configuration LDAP
  • Configuration Network
  • Configuration Netload Limiter
  • Configuration PLCnext Store
  • Configuration Proficloud
  • Configuration NTP
  • Configuration System services
  • Configuration Security Profile
  • Configuration Syslog
  • Configuration Web services
  • Configuration License management
  • Configuration DataLogger
  • Configuration Safety PLC
  • Configuration Project integrity
  • Configuration Port authentication
  • Configuration OPC UA server
Certificates
This encompasses all certificate files stored in the Trust Stores and Identity Stores. Of course, on a different device certificates depending on the Trusted Platform Module (TPM) cannot be restored.
Engineer project
This contains the PLCnext Engineer project data including the safety-related project data, and the default project, which also covers the OPC UA® server and OPC UA® client settings.
Runtime data
For backing up, this category contains all runtime data. Note: With this selection no configuration data for Proficloud or DataLogger is included. For that, select the Configuration data
  • Runtime data Proficloud
  • Runtime data DataLogger
PLCnext Apps binaries
This selection contains the binaries in the directory for all installed PLCnext Apps; there's no means to select a single app.
PLCnext Apps runtime data
This selection contains the runtime data in the directory for all installed PLCnext Apps; there's no means to select a single app.
Remaining files
This selection contains all added or modified files from the Overlay File System.
Note: Not included in any of the backup/restore categories are these data categories:
  • Retain data (could only be stored when device is powering down, not just when stopped)
  • Log files
  • Notifications
  • SD card configuration
  • Licenses
Additonal features
Available from firmware 2026.0 LTS
The archives from this WBM2 page can be locked by means of a password that has to be typed in before backing up and before restoring from that package.
Those archives can be downloaded from the device and uploaded to a device, even to a different device of the same type and with the same firmware version.
This seems to be helpful for "cloning" devices, but some settings can never be restored on a different device (such as Identity Stores and licenses).
Note: Using this backup & restore feature for deployment is not recommended and Phoenix Contact assumes no responsibility or liability.
How to use this feature
Backing up data
  • For creating a backup package, click the + button below the table of available backups.
    ↪ A 5-step modal dialog is displayed; you can always return to a former step by clicking the back button.
  • In step 1, select the data categories you want to have in this backup package, then click the next button.
    Note: Backing up some types of data requires stopping the PLCnext Runtime.
  • In step 2, make your choice:
    • If no data has been selected that requires as stop then you may skip stopping the PLCnext Runtime.
    • If data categories are selected that require a stop, click the prepare and stop button.
      ↪ The device state changes to Prepared and stopped.
      Note: In case you cancel the procedure from this step you need to click the start and resume button in the Status section.
  • In step 3, enter a meaningful name for the backup file to label the content of the package, then click the next button.
    ↪ The string it is appended to the serial number of the device and the current timestamp; this way, your can use the same label for the same sets at different timepoints.
  • In step 4, click the create backup button.
    ↪ If necessary, the device state changes to Prepared and stopped.
    ↪ The backup procedure is performed.
  • In step 5, click the START AND RESUME button.
    ↪ If necessary, the device state is resumed to Running.
    ↪ The modal dialog closes and you should see the new backup file in the table.
Restoring data
  • For restoring data from a backup package, click the restore button in the respective row in the table of available backups.
  • In step 1, select the data categories you want to restore from this backup package, then click the next button.
    Note: Restoring some types of data requires stopping the PLCnext Runtime.
  • In step 3, click the REStorE button.
  • In step 4, make your choice:
    • If necessary (e.g. if you want a restored configuration to be used), click the restart the device button.
      ↪ The device is restarted; re-enter the WBM 2, navigate to the Backup & restore page, then click the start and resume button in the Status section.
    • Otherwise, click the next button.
    ↪ The modal dialog closes.
• Published/reviewed: 2026-04-21  ✿  Revision 093 •
