Updating the firmware
Note: If the boot process failed five consecutive times then the inactive and the active boot partition will change their roles. This behavior has been implemented to keep the PLCnext Control device accessible even if the firmware update fails.
The behavior can also occur when the boot process is interrupted e.g. by power loss. In this case you will observe that the PLCnext Control boots with its previously installed firmware version. To prevent such unintended firmware downgrades, Phoenix Contact recommends that after a finally successful firmware update, the same firmware should be installed once again. This way both the active and the inactive boot partition will contain the same firmware version.
