Security Profile: Uploading the certificate in the browser
  • Log in to the WBM.
  • Open the Security → Certificate Authentication page in the WBM.
  • Open the Identity Stores tab.
  • In the HTTPS-self-signed area, download the certificate you just generated by clicking the  button ("Download from controller to local pc") next to the certificate.
  • Open your browser (Edge).
  • Open the Settings menu.
  • Open the Privacy, search, and services tab .
  • In the Security section, click the Manage certificates button.
    ↪ A new window opens.
  • Open the Trusted root certificates tab.
  • Click the Import... button.
    ↪ The "Certificate Import Wizard" opens.
  • Follow the instructions of the "Certificate Import Wizard".
  • Select the certificate you want to import and click the Open button.
  • Click the Next button.
  • Select Place all certificates in the following store and click the Browse... button.
  • Set the certificate store option to Trusted root certificates and click the OK button.
  • Click the Finish button.
  • If a warning note opens, read the warning note and in case you want to confirm it, click the Yes button.
    ↪ The certificate was uploaded in the browser.
  • Check the status of the certificate in your browser.
