Secure by default: Activating HMI
Activating PLCnext Engineer HMI
 For information on how to create a PLCnext Engineer HMI application, refer to the topic Creating a PLCnext Engineer HMI application in the PLCnext Technology ‑ Info Center
 For information on user roles and permissions, refer to the User management WBM topic in the main PLCnext Technology ‑ Info Center
Before you can use an HMI application with an activated Security Profile, you must activate the PLCnext Engineer HMI. To do this, proceed as follows:
  • Log in to the WBM.
  • Open the System services page (SystemSystem services) in the WBM.
  • Activate the toggle switch of the PLCnext EngineerHMI.
  • Click the SAVE PAGE & RESTART button.
After the PLCnext Control has rebooted, you can use your HMI application.
Adding and editing the login dialog
Note: Log in with the Engineer user role (information on this can be found in the topic Creating users ).
In the security context, every access to an HMI application must be secured via a login dialog. This must contain a corresponding system use notification. PLCnext Engineer provides a page template with a login dialog with a system use notification that you can insert into your project.
To insert the login page template into your project, proceed as follows:
  • Open your project in PLCnext Engineer.
  • In the COMPONENTS area, right-click the Login page template (ComponentsHMIDefaultPage Templates → Login).
  • Click Create HMI Page
    ↪ The login page template is now a child element of the HMI Webserver node in the PLANT area.
  • In the PLANT area, double-click the login page template.
    ↪The HMI editor group with the associated editors is opened.
  • On the HMI Page tab, read the contained system use notification and check whether the text is valid for the respective application in the respective jurisdiction and adapt it if necessary. If necessary, consider the respective national language.
  • To edit the default system use notification, double-click the text.
  • You can create different language variants of the system use notification. To display the system use notification in another language, select the Send to Back menu item in the context menu.
  • Save your project.
The login dialog is ready for use in the security context.
