Secure by default: OPC UA® security compliance list
Note: You must always use sign & encrypt.
OPC UA® Server
Profile: Embedded 2017 UA Server
Facets:
- Global Certificate Management Server Facet
- User Token - User Name Password Server Facet
SecurityPolicy:
Available as sign and as sign & encrypt:
- Basic256Sha256
- Aes128-Sha256-RsaOaep
- Aes256-Sha256-RsaPss
OPC UA® Client
Profile: Minimum UA Client Profile
SecurityPolicy:
- Basic256Sha256
OpenSSL
Note: The OPC UA client and server use the OpenSSL library to validate X.509 certificates using the OpenSSL flag
X509_V_FLAG_X509_STRICT. As firmware 2024.0 LTS is updated to OpenSSL 3.0, the X.509 certificate validation became more strict, especially for non self-signed certificates. This may cause the server to return the error BadSecurityChecksFailed on client connection attempts. Make sure that, according to OPC UA Part 6, client issuer as well as client application X.509 certificates are conform to RFC 5280, especially to the sections listed below. The same applies for user-managed server certificates.
- 4.1.1.2 signatureAlgorithm
- 4.1.2.6 Subject
- 4.2.1.1 Authority Key Identifier
- 4.2.1.2 Subject Key Identifier
- 4.2.1.3 Key Usage
- 4.2.1.6 Subject Alternative Name
- 4.2.1.9 Basic Constraints
• Published/reviewed: 2026-04-20 • Revision 022 •
