Documentation (PDF and CHM)
The documentation of the library must be saved as a *.pdf file in the *.zip folder and uploaded to the PLCnext Store. Ideally, you should also create this documentation as a *.chm or *.html file.
For examples of how the documentation can be structured, go to the PLCnext Store and open a Phoenix Contact library documentation of any library. Please create the documentation as in these examples.
Note: If you want a template for the documentation, please contact the PLCnext Store admin. He can provide you with an appropriate template.
The following points must at least be included:
Cover with the following information:
- Name and version of the library
- Revision of the documentation
- Release date
Table of content
General information (description) about the library
A change notes table with one row for each library version:
Library version | Library build date | PLCnext Engineer version | Changes to the previous version |
2 | yyyy-mm-dd | 2021.0 LTS |
New:
Bugfix:
1 | yyyy-mm-dd | 2020.0 LTS | Converted from PC Worx 6 |
Overview of the functionblocks, ideally structured in tables:
Function block | Description | Version | Supported products |
FB_Name | Lorem ipsum dolor sit amet, consetetur sadipscing elitr, … | 1 | Communication module AXL SE RS232 (item no. 1181787) |
Supported PLCs and firmware
For each POE (FB or FC):
- Functional description of the POE
- Screenshot of the POE in FBD (functionblock diagram)
- Three tables (input parameters, output parameters, inout parameters) with the description for each connection: Name, type, description
Name Type Description xActivate BOOL Rising edge: Activates the function block.
FALSE: Deactivates the function block. - One table with all diagnostic codes of this POE: Diagnostic code, additional diagnostic code (if applicable), description
wDiagCode wAddDiagCode Description 16#0000 16#0000 Function block is deactivated. 16#8000 16#0000 Function block is in regular operation.
Documentation of used system variables:
- Name
- Type
- Description
Documentation of user relevant structures:
- Name
- Type
- Description
A startup example:
- Description of the startup example
- If applicable, then the necessary hardware and start-up parameters
- Explanation of different POE states or functionalities:
- Description
- Screenshots of the POE connections with activated online values
Third party licenses
- "This software makes use of third party packages with different licenses. The software packages and the licenses are listed in this chapter."
- List of all licenses with a reference to where the licenses can be found.
Contact information (e.g. email address) for support
Go back to Overview.
• Published/reviewed: 2025-06-30 • Revision 20 •
