Preparing a PLCnext Control Solution
- Make sure that your PLCnext Control Solution is already executable on your PLCnext Control.
Note: If you want to publish your solution with a chargeable license, insert the function block LICENSE_STATUS from the "PLCnext Controller" library into your PLCnext Engineer program.
- Log in to your PLCnext Store account and create a new solution.
- To create a new solution, go to the "Software Products" tab on your profile and click the button.
- In the submenu that opens, select "PLCnext Control Solution".
A new page opens.
- Fill in the fields on the Core Data tab.
- Add an icon.
- Write down the Firm Code / Product Code of your created solution.
You will need the App Identifier (the combination of Firm Code / Product Code) later when creating the app description file.
Note: If you want to publish your solution with a chargeable license, add the Firm Code / Product Code to the function block LICENSE_STATUS and activate it.
- Save your solution as a draft.
As long as the solution is saved as a draft, the solution is not publicly visible and is editable for you at any time.
→ Next step: Building a solution.
Or go back to Overview.
• Published/reviewed: 2025-06-30 • Revision 20 •
