Publishing a solution
- Go back to the PLCnext Store.
- Go to Account → Software Products.
- Open the "Drafted" drop-down menu.
- Click the button next to your solution.
- In the submenu that opens, click the button.
You are now back in edit mode.
- Fill in the remaining fields of the app description.
- Upload the *.app file to the PLCnext Store.
- Click the button.
- In the window that opens, click the button.
- Test the installation by clicking the button next to your solution. In the submenu that opens, select "Install".
To test the installation, proceed as follows:
When you are satisfied, you can publish the solution in the PLCnext Store and make it publicly available. To publish the solution, proceed as follows:
Your solution will be automatically moved from the "Drafted" section to the "Published" section.
The more descriptive documents (such as technical details, screenshots) you upload, the better the customer can use your app.
And remember: Only a satisfied customer gives a good rating.
Go back to Overview.
• Web browser recommendation: Chrome/Edge 88 or newer, Firefox ESR 90 or newer, or Safari •
• Published/reviewed: 2024-06-04 • Revision 15 •
