Online: installing a library license
Note: With a library only the license is transferred to the device.
Requirement: Your device is registered in the PLCnext Store using the UUID. For more information, refer to the topic Connecting a PLCnext Control with the PLCnext Store.
- To install a license, click on → Install.
On the following page you can see your previously registered devices.
- Select the device on which you want to install the license.
- Click on .
The license will now be installed on your device.
- Check the progress of the installation in the device list.
The license has been transferred to your device.
Note: On the License Management (Administration → License Management) page in the WBM you can see which licenses are currently on your device.
See also
• Published/reviewed: 2026-07-09 • Revision 26 •
