Creation of an app container
The Linux command plcnextapp is available under /usr/bin and is used to create an app container.
The following parameters are supported:
- create <APPDIR> <APPNAME>
- e.g.: plcnextapp create /opt/plcnext/myapp My App
- example
- e.g.: plcnextapp example
"create":
Creates a SquashFS app container file APPNAME.app from the selected app folder "APPDIR".
"example":
Creates a simple empty app container folder which contains a minimal app_info.json file and the sample empty folders "arp", "bin", "lib" and at least "sbin".
Note: The tool can handle further commands but except "create" all commands are intended for operation by the AppManager and do not have the desired effect when called via the command line.
Note: The set access rights to all app files and directories are retained when the container is created, but the ownership information of these files and directories will be lost/forced on app creation.
• Published/reviewed: 2025-12-18 • Revision 22 •
