Use gRPC to interface Python scripts with PLCnext Engineer Projects.
Pedro_Aguilar 28 May 2025 min. read
2,265 views 1 comments
The following information serves both as an update and an expansion to this post from 2022.
The approach works the same for the AXC F 2152 and the AXC F 3152, the difference resides on how to install the required libraries.
IMPORTANT: The approach has been tested and seen working for FW 2024.x and 2025.0
For the AXC F 2152:
The libraries grpcio and grpcio-tools need to be cross compiled off device and be installed manually. An overview on the approach I take to perform the cross compilation using QEMU can be found on this forum entry
The cross compiled libraries for Python 3.11, together with the rest of the files to follow this post, have been made available via this link
The following instructions allow you to create a container with Python 3.11 where you can run the scripts that make use of gRPC.
  1. Using WinSCP (or some other software that allows accessing the file system of your controller), create a folder in /opt/plcnext to be used for the gRPC communication, this example will assign the name "grpc2152" to that folder. within grpc2152, create the following folder structure.
grpc2152/
├── include/
│     └── google/
│	    └── (empty folder for now)
├── whl_files311/
│        ├── grpcio-1.71.0-cp311-cp311-linux_armv7l.whl
│        └── grpcio_tools-1.71.0-cp311-cp311-linux_armv7l.whl
├── generate_googlegrpc.py
├── grpc_test.py
└── Readme.txt
  1. Download the repository "https://github.com/PLCnext/gRPC" and from there, take the folder "protobuf" and place it inside the previously-created google folder. The resulting folder structure then looks like this:
grpc2152/
├── include/
│        └── google/
│	       └── protobuf/
│		     └── (content of the protobuf folder from the PLCnext github repo)
├── whl_files311/
├── grpc_test.py
└── Readme.txt
  1. Create a SSH session to your PLC, log in as root user (su) and get the slim version of python 3.11. (at this point, internet connection is necessary to get the python image)
$ podman pull docker.io/library/python:3.11.10-slim-bookworm
  1. Run and attach to the container (linking the folder grpc2152 as a volume and a second volume (run) necessary for the connection to the grpc socket):
$ podman run -it -v /opt/plcnext/grpc2152:/grpc2152 -v /run:/run --restart=always --name grpctester python:3.11.10-slim-bookworm /bin/bash
  1. Once attached to the container console, navigate to the folder whl_files311 and install the grpcio libraries. (internet connection is necessary for the dependencies)
	$ cd /grpc2152/whl_files311/
	$ pip install *.whl
  1. Go back to the parent folder grpc2152 within the container and execute the python script "generate_googlegrpc.py" (some messages should appear -working!-)
	$ cd /grpc2152
	$ python3 generate_googlegrpc.py
  1. Once the script has successfully finished execution, a new folder should be present (pxc_grpc). Inside grpc2152, the python snippets for grpc are now located there. Now you can test the gRPC functionality with the example project and script.
  2. Download and start the PLCnext Engineer project "TestingGRPC.pcwex" to the controller.
  3. Test the gRPC functionality from the console of the container by executing the "grpc_test.py" script. In the PLCnext Engineer project, accessing the variables in debug mode, the content of the variables should be populated with the values from the script.
For the AXC F 3152.
Follow the same procedure given above for the 2152 but in the step 5, install the libraries directly from pypi.org
	$ pip install grpcio==1.71.0
	$ pip install grpcio-tools==1.71.0
Data Types and making use of the code snippets.
Now, whenever you want to make use of gRPC for accessing variables, include the folder where the code snippets were generated to the Python path used by your scripts and import the necessary classes (line 6 to 14 of the given grpc_test.py file).
Remember to consider the data types outlined in the old post that I mentioned at the beginning of this article.
fabian 23.06.2025
Thank you very much for this post, I found it extremely helpful and it worked fine for me on a AXC F 2152 with FW 2025.0.2. Since I want to develop a Python application that connects to the GDS by using gRPC, I am now thinking about a good setup for developing and debugging. I tried installing openssh-server within the OCI-container so that I can connect with my Python-IDE (Visual studio code) directly to the container on the AXC F 2152, but I wasn't successful. I have the server running and I am able to connect from the host (AXC F 2152) to the ssh-server within the container, but forwarding port 22 between the container and the host machine so that I can connect directly from my windows-machine to the container didn't work (I wasn't able to find the reason). Do you have some advice for a development and debugging setup? Thanks and kind regards Fabian
Pedro_Aguilar 08.10.2025
Hello Fabian, thank you for your feedback and sorry that it took me so long to answer your comment. Sadly I dont have any suggestion for your problem. I mostly work offline first on my PC and then download manually the scripts to my PLC. However, if you in the end managed to make it work (connect via SSH directly to the container), it could be interesting for other people if you share how you did it here in the community.
