Read and Write PLC Process Data with Python
nilshettig 16 March 2022 min. read
11,650 views 3 comments
Scope
This article describes how to access and write process data with Python utilizing the PyPlcnextRsc library. You can find the library’s documentation here. This page also provides examples for creating and handling complex data structures. If the described techniques do not meet your requirements, you are good to go to the man-page.
Update for firmware version 2022.0.3 LTS
The PyPlcnextRsc library was updated to be compatible with the firmware 2022.0.3 LTS. Previous versions (< 0.1.10) caused an error during the connect process device.connect(). For firmware versions < 2022 no update is required. Nevertheless, it is possible to update the Python package with the following commands:
alias pip='/opt/plcnext/.local/bin/pip'
pip install -U pyplcnextrsc
Prerequisite
  1. The PLC must have internet access.
  2. Install the Python package manager pip if it is not on the PLCnext device yet. You can check it by logging into the PLC and type pip or pip3, and hit enter. If pip is installed, some version information is displayed. Otherwise, install pip:
    curl https://bootstrap.pypa.io/get-pip.py -o get-pip.py
    python3 get-pip.py
  3. Install the required package: pip install -U PyPlcnextRsc
Read & Write Process Data
With the following example, we read process data:
# required imports
from PyPlcnextRsc import Device, RscVariant, RscType
from PyPlcnextRsc.Arp.Plc.Gds.Services import IDataAccessService, WriteItem
# we have to login using the standard credentials
# it is not recomended to store the login data in code
# the following example should only show how to interact with the process data
secureInfoSupplier = lambda:("admin","password")
# login to the device
device = Device('127.0.0.1', secureInfoSupplier=secureInfoSupplier)
device.connect()
# service to access the process data
data_access_service = IDataAccessService(device)
# read one variable
read_item = data_access_service.ReadSingle("Arp.Plc.Eclr/test_in2")
# read multiple variables
read_items = data_access_service.Read(("Arp.Plc.Eclr/test_in1", "Arp.Plc.Eclr/test_in2", ))
read_item1 = read_items[0]
read_item2 = read_items[1]
# get the value of the read_item
value = read_item.Value.GetValue()
# get the data type of the read_item
value = read_item.Value.GetType()
Differences exist concerning the type of process data we want to access:
# Extern variable:
# Arp.Plc.Eclr/
# Local variable:
# Arp.Plc.Eclr/.
read_item = data_access_service.ReadSingle("Arp.Plc.Eclr/MainInstance.test_in2")
# Function block variable:
# Arp.Plc.Eclr/..
read_item = data_access_service.ReadSingle("Arp.Plc.Eclr/MainInstance.myFB.test_in2")
And last here is the code to write data:
# first create the variable containing the value and the data type
rscv = RscVariant(16,RscType.Int16)
# create a WriteItem with the destination process variable
wi = WriteItem("Arp.Plc.Eclr/MainInstance.test_in3", rscv)
# write single process variable
data_access_service.WriteSingle(wi)
# write several process variables
data_access_service.Write((wi1, wi2,))
For the different data types, please visit the library’s documentation.
gjduesseldorf 14.03.2022
Hello, I'm using the firmware 2022.0.3 LTS on an AXC F 2152. I successfully installed the PyPlcnextRsc package. I imported the required modules. I built the login configuration. But device. connect() creates these errors: admin@axcf2152:~$ python3 Python 3.8.11 (default, Jun 28 2021, 10:57:31) [GCC 9.3.0] on linux Type "help", "copyright", "credits" or "license" for more information. >>> from PyPlcnextRsc import Device, RscVariant, RscType >>> from PyPlcnextRsc.Arp.Plc.Gds.Services import IDataAccessService, WriteItem >>> secureInfoSupplier = lambda:("admin","password") >>> device = Device('127.0.0.1', secureInfoSupplier=secureInfoSupplier) :1: FutureWarning: CURRENT ONLY FOR INTERNAL TEST USE !!! >>> device.connect() Traceback (most recent call last): File "/usr/lib/python3.8/site-packages/PyPlcnextRsc/common/transport/rsc_sock. py", line 178, in connect self._socket.connect(self.info.getAddr()) File "/usr/lib/python3.8/ssl.py", line 1342, in connect self._real_connect(addr, False) File "/usr/lib/python3.8/ssl.py", line 1333, in _real_connect self.do_handshake() File "/usr/lib/python3.8/ssl.py", line 1309, in do_handshake self._sslobj.do_handshake() ssl.SSLError: [SSL: TLSV1_ALERT_PROTOCOL_VERSION] tlsv1 alert protocol version (_ssl.c:1131) During handling of the above exception, another exception occurred: Traceback (most recent call last): File "", line 1, in File "/usr/lib/python3.8/site-packages/PyPlcnextRsc/common/device.py", line 179, in connect self._rscClient.connect() File "/usr/lib/python3.8/site-packages/PyPlcnextRsc/common/transport/rsc_client.py", line 85, in connect self.socketWrapper.connect() File "/usr/lib/python3.8/site-packages/PyPlcnextRsc/common/transport/rsc_sock.py", line 184, in connect raise CommonRemotingException(message="Can not connect to device", cause=e, err=ErrType.SOCKET_UNSPECIFIED) PyPlcnextRsc.common.exceptions.CommonRemotingException: ('Can not connect to device (SOCKET_UNSPECIFIED)', SSLError(1, '[SSL: TLSV1_ALERT_PROTOCOL_VERSION] tlsv1 alert protocol version (_ssl.c:1131)')) What is missing? Many thanks Götz (Goetz.Jaeckel@GJ-Didaktik.de)
Nils Hettig 15.03.2022
Dear Mr. Jäckel, I’ve just encountered the same error, when using the latest firmware 2022.0.3 LTS. However, it worked with the firmware 2021.9. Probably some security mechanisms have changed since the error indicates an incompatible TLS version. As a first workaround I would recommend downgrading the firmware. Since I was not involved in the development of the Python library, I could not fix the error. Nevertheless, I will contact my colleague who developed the library and ask for support. When I get news, I will inform you via this channel. Hope that helps. If you have further questions don’t hesitate to contact me. Best regards Nils Hettig
Dominique Rakowski 16.03.2022
Hi, We have a customer that is interested in using this solution to read/write datas on the PLC, but he also needs a specific package for his Python application, which doesn't work on our Linux distribution. We told him he could use a Docker container, so I tried to use this package inside a container but there are some issues : root@dc0cbfda6a0b:/opt# python3 test_docker.py /opt/test_docker.py:11: FutureWarning: CURRENT ONLY FOR INTERNAL TEST USE !!! device = Device('192.168.254.52', secureInfoSupplier=secureInfoSupplier) Traceback (most recent call last): File "/usr/local/lib/python3.10/site-packages/PyPlcnextRsc/common/transport/rsc_sock.py", line 178, in connect self._socket.connect(self.info.getAddr()) File "/usr/local/lib/python3.10/ssl.py", line 1374, in connect self._real_connect(addr, False) File "/usr/local/lib/python3.10/ssl.py", line 1365, in _real_connect self.do_handshake() File "/usr/local/lib/python3.10/ssl.py", line 1341, in do_handshake self._sslobj.do_handshake() ssl.SSLError: [SSL: NO_CIPHERS_AVAILABLE] no ciphers available (_ssl.c:997) During handling of the above exception, another exception occurred: Traceback (most recent call last): File "/opt/test_docker.py", line 12, in device.connect() File "/usr/local/lib/python3.10/site-packages/PyPlcnextRsc/common/device.py", line 179, in connect self._rscClient.connect() File "/usr/local/lib/python3.10/site-packages/PyPlcnextRsc/common/transport/rsc_client.py", line 85, in connect self.socketWrapper.connect() File "/usr/local/lib/python3.10/site-packages/PyPlcnextRsc/common/transport/rsc_sock.py", line 184, in connect raise CommonRemotingException(message="Can not connect to device", cause=e, err=ErrType.SOCKET_UNSPECIFIED) PyPlcnextRsc.common.exceptions.CommonRemotingException: ('Can not connect to device (SOCKET_UNSPECIFIED)', SSLError(1, '[SSL: NO_CIPHERS_AVAILABLE] no ciphers available (_ssl.c:997)')) The docker container is the official Python image with the latest tag. If you need more information, feel free to ask, Cheers,
gjduesseldorf 18.03.2022
Thanks Gentlemen, it works!
MathieuCalloens 18.03.2024
Hi. I'm using the axc f 2152 controller with frimware 2023.6.0. I used this example to read/write to the PLC via the commandprompt and ssh. This works fine. I wanted to use the PBCL_SysLinuxShell from the PLCnextBase library to call the script so I don't have to manually copy it in terminal.When I execute it, the functionblock says it's busy and it stays busy. I dont'get a confirmation it's done nor a result. I ran the script line by line and it seems to be stuck at "device.connect()". Any idea why it won't connect when using this FB? Below you can find the pythoncode I use. Many thanks. from PyPlcnextRsc import Device, RscVariant, RscType from PyPlcnextRsc.Arp.Plc.Gds.Services import IDataAccessService, WriteItem secureInfoSupplier = lambda:("admin","password") device = Device('192.168.0.10', secureInfoSupplier=secureInfoSupplier) device.connect() data_access_service = IDataAccessService(device) read_item = data_access_service.ReadSingle("Arp.Plc.Eclr/rScaled") value = read_item.Value.GetValue() print (value)
Martin PLCnext Team 18.03.2024
I note that this question was also asked in the PLCnext Community Forum, where an answer was given by the developers of the PLCnextBase library.
